Old 11-20-2010, 03:15 PM
Microtrol's Avatar
Microtrol Microtrol is offline
seeing double
Hi all,
so far this forum has been a great source of information and once again I am back again. I have repaired the connector on my 12lp4 tube (help from here) and started up the Philco 49 tv and the picture tube comes up. Now i am using a vcr as the input and i get a picture although ugly, but it shows up as two images stacked vertically (see pic). The tv locks horizontally and vertically but has the two images. any suggestions?
Thanks,
Old 11-20-2010, 04:07 PM
Your Vertical oscillator is running too slow by half so you are getting two pictures stacked on top of each other.
Look for a seriously out of spec resistor or an incorrect capacitor in the Oscillator tube circuit.
What happens when you turn the vert hold control?
Old 11-20-2010, 04:40 PM
Microtrol's Avatar
When the vert control is adjusted the screen starts to roll, and will stop at any one of the half screen start positions, I ill check the oscillator area for incorrect values, thanks
Old 11-20-2010, 06:44 PM
Microtrol's Avatar
Ok, I looked over the osc circuit and found that i had left a older original orange drop cap in the unit thinking it should be ok, replaced it and voila, single screen, it periodically looses vert lock but I did place just a temp cap with a close value and need to install a proper cap. found 5 more of the older caps and will replace them later on, once agin, thanks for the info, you guys are lifesavers.
Old 11-20-2010, 10:36 PM
Big Dave's Avatar
Big Dave Big Dave is offline
Dead from the neck up
Look for and replace any micamolds. If you see what looks like a mica, but its value is 1000pf or more, replace it.
The world's worst TV restoration site on the entire intranoot and damn proud of it.
http://evilfurnaceman.tripod.com/tvsite
