Old 12-26-2010, 07:10 PM
ctc17 ctc17 is offline
My experience is the set goes through a 2nd infant mortality. Whats going to fail usually does withing a few weeks. Once you get past that it should be fairly reliable. You can recap it and that will help but then something random like a detector diode or pot will fail.
Im not big on fans, they bring in tons of dust and the HV already attracts enough on its own.
Dave is right on with lowering the voltage. That really helps with the heat.
Also I wouldnt recommend aligning anything that required turning slugs until I ran the set for a few weeks with the new caps.
Old 12-26-2010, 08:27 PM
Originally Posted by DaveWM View Post
the fly def will prefer the lower line voltage, I can drop it to 105-110 and have no bad effects, and drop the HOT current by 10% easy..
I generally only run the sets for about 1-2 hrs tops anyway.
One caution - some sets may not like the B+ TOO low, because it may reduce the drive to the horizontal output. Best bet is to monitor the B+ and set it for nominal or only slightly low, I would guess.
Old 12-26-2010, 08:33 PM
heathkit tv's Avatar
heathkit tv heathkit tv is offline
VK Member
Great tip on holding of on the alignment. One possibility to reduce or eliminate dust when using a fan is to take a page out of diesel locomotives...they filter the air that's used to cool the engine compartment. This does two things, not only is the air that's brought into the compressor filtered, it also pressurizes the loco so that ambient dust etc can't migrate in.
Needn't be anything too complicated, even a cheese cloth may suffice. One thing to watch out for would be if the fan failed for any reason the available convection cooling may not be enough.
Old 12-26-2010, 11:10 PM
Chad Hauris's Avatar
A big problem I have seen with RCA's and RCA-clone type sets is that wiring gets burned from power resistors under the chassis. After replacing burned wiring in a CTC-28, I relocated a power resistor which was on a burned terminal strip near cooked wiring out in front of the chassis so it is underneath the picture tube. There is a lot more open air for cooling there and it is not near any wiring.
I also found the high line voltage tap on the power transformer and wired it up in the power supply along with adding a 115VAC coil relay to switch the power. I came across a whole bunch of 115VAC relays and sockets and this takes the heavy current load off the power switch.
Chad Hauris
Old 12-27-2010, 09:26 PM
WA3WLJ's Avatar
WA3WLJ WA3WLJ is offline
Power Surge
Great idea Chad on the relay, I'm surprised you guys don't leave the sets on at a predetermined volume and use a power strip for on /off.............
Old 12-27-2010, 11:19 PM
damen's Avatar
damen damen is offline
That's what I do and the fans plugged into it to.
Old 12-28-2010, 12:06 AM
JoeNewberry's Avatar
JoeNewberry JoeNewberry is offline
Why is it not possible to just add a resistor to the live side of the line cord to reduce the incoming line voltage?
Old 12-28-2010, 12:17 AM
Old 12-28-2010, 12:35 AM
As far as the power switch goes...you just need to the set on at the lines zero crossing point.
Old 12-28-2010, 01:38 AM
WA3WLJ's Avatar
Timing is everything !!!
PZT !!!
Old 12-28-2010, 10:16 AM
VK Member
How about running the sets on a timer with the volume down? Haven't looked, but I bet there's a programmable timer somewhere that'll permit once a week or even once a month activation. I think one of my exes had one of those LOL
