Old 01-16-2011, 04:33 PM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
RCA to Zenith Convergence Swap - Would this work?
I was just curious if the three dynamic convergence coils on the neck of a 21FJP22 from an RCA set could replace the same components in a Zenith set. My Zenith roundie has the plastic cased convergence coil assembly which is prone to cracking. The RCA sets with the same tube seem to have a more robust assembly without the plastic shell. Could the RCA unit be used in the Zenith since the CRT is the same? Has anyone tried this?
Old 01-16-2011, 10:55 PM
Don't know - do they at least measure the same resistance?
Old 01-17-2011, 12:19 AM
reeferman's Avatar
My bets are it wouldn't work, but what do you have to lose?
Old 01-17-2011, 10:37 AM
kx250rider's Avatar
REAL TVs have TUBES!
Never tried it. I wouldn't recommend it unless one of our engineer-AKers writes it up. If the impedance is wrong, it might overtax the flyback or other very unpleasant things.
Charles
