The resistor elimination in the 21CT55 matrix from the CT100 design was a patent dodge. RCA did not want to pay royalties on I/Q demodulation. Well, thats the story I heard. RCA was known to do almost anything to avoid paying royalties.
John Folsom |
I do not have a CTC2B chassis to test my theory, but one must rule out the possibility that the CTC2B chassis does not properly decode the color signal transmitted by an NTSC broadcast transmitter. The two color signals, I and Q, that are trasnmitted by NTSC standards are in quadrature. In the CTC2B the decoded chroma, Q and R-Y, are not. When a quadrature signal is encoded, it must be deconded in quadrature if crosstalk is to be minimized. If I am right, the CTC2B chassis is inferior to the CTC2 chassis when decoding an NTSC broadcast. Now, it is always possible that some stone has been left unturned by me. Perhaps eliminating the one insignificant-in-cost resistor in the CTC2B matrix somehow negates the not-in-quadrature problem. I don't know. BTW: I believe it was probably Philco that RCA was dodging. Pete Last edited by Pete Deksnis; 02-15-2011 at 10:51 PM. |
Comparisons before and after FBX replacement.
Here are preliminary comparisons of the original FBX vs the replacement FBX installed in my 21CT55. The screen is still too wide, must be the original yoke is more sensitive then the newer yokes intended to be driven by the replacement FBX. No, I wont try to find a newer yoke………..Tom
RCA was the last major mfr. to use intercarrier audio. I guess Sarnoff didn't want to lower himself to paying royalties to Motorola Inc.
Frankenstien Lives!
Here are some later screen pics of the Ferris Day Off. The stitches are before and after FBX swap. Some are after vs Sony. With the exception of too much width, picture quality re facial color graduation and non-combfiltered fine detail, typical of my 21CT55 aka Frankenstein, has been restored. Following advice of this thread, I purchased at great expense DVD of Wizard of Oz and Blu-ray of Gone with the Wind ($10 and $12 respectively. I am now ready for the Lollipop Color of the original Technicolor. I hope I'm not disappointed………………Tom,
Looking real good Tom!
Look forward to lolipop color screen shots on the old gem. 1938 "Robin Hood" is another good one for Technicolor, and I use it often with the 4.Kevin
stromberg6 |
It's alive, Its alive! Tom you should change the title of this thread. Your 21-CT-55 is most certainly resuscitated.
-Steve D.
Please visit my CT-100, CTC-5, vintage color tv site: http://www.wtv-zone.com/Stevetek/ |
