Speaker of hot chassis, there's a big 54 ohm 20W resistor running down one side to drop the filament voltage. Here's the series wired tube lineup: 3.15 - 3BC5 4.70 - 5J6 3.15 - 3CB6 3.15 - 3CB6 6.30 - 6BA8A 4.70 - 5U8 3.15 - 3DT6 12.6 - 12CU5 6.30 - 6CM7 6.30 - 6CG7 12.6 - 12DQ6 12.6 - 12AX4GTA 6.30 - 10ABP4 ---- 85 @ 600mA I plugged that into this website Reece tipped me off to and got this. note: I used 120 for the supply voltage. If I use 117, I get 53 ohms @ 19.2 W. * Dropper resistor = 60 ohms @ 21.6 W * Dropper resistor with diode = 1 ohms @ 0.3 W * Dropper capacitor = 22 uF + 17 ohms @ 6W I like the idea of shaving off most of that wasted 20W. Has anyone tried the diode or capacitor method in a series string TV set ? |
