Old 03-27-2011, 10:32 AM
pulled the tuner out, the 100ohm was 300ohm off that pot. I need to go ahead an pull the entire chassis, will replace those other parts (the screen resistors and that coupling cap. there are some .001 disc caps across the G2 pots that I am tempted to replace while I have it out, just in case one of those is acting up causing that intermittant problem. The only thing is I never really captured it on the VTVM to confirm it was the G2 voltage that was doing it. could have been the G1 or the cathode I suppose. Just getting tired of yanking the chassis as you have to pull the tuner with it.
