Old 04-20-2011, 06:52 PM
ohohyodafarted's Avatar
Bob Galanter
Wayne,
Your 21ax is already on my list of stuff to bring along. If you would like to test them at the convention, I will also have my Hot Wire tool so we can remove the gun assembly and connect the leak detecttor to the tube. We have a special adapter that connects to the 52mm neck glass and seals with an "O" ring. But the gun must be removed in order to connect up.
See you at the convention.
ME http://AntiqueTvGuy.com
