Old 04-26-2011, 10:41 PM
Penthode's Avatar
Penthode Penthode is offline
Originally Posted by JCFitz View Post
It's 1 and 3/4 in diameter and 2 and 9/16 from screwhole to screwhole and the same from front to back.It takes an octal tube such as the 1B3.
The socket itself is a separate piece from the actual cup but it was glued in place during manufacture.
Thanks!!
I measured my socket. It is a bit bigger: 3 3/8" screw hole to screw hole and 2 5/8" diameter. It has an octal socket and a corona ring holds the socket in place with solder (as originally manufactured).
Would this fit?
Old 04-29-2011, 02:52 PM
JCFitz JCFitz is offline
Would this fit?
It would only work if it it didn't have to go through that hole in the chassis.In other words if it was made like my zenith color HV cup.It has a flat bottom and everything comes out of 1 side.I could rewire the HV wires for something like that.
