Old 05-01-2011, 08:08 PM
ggregg's Avatar
ggregg ggregg is offline
Originally Posted by ggregg View Post
Electroytics are usually 1-2 mfd (microfarad) or higher. You usually won't see one lower than a 10 or 8 mfd. That .1 mfd you have in your hand is not an electrolytic.
I meant to say you usually won't see one lower than a 10 or 4 mfd.
Good luck, ask for help if you need it.
Old 05-01-2011, 08:23 PM
Here are more articles that may be helpful. The first one covers recapping:
http://antiqueradio.org/recap.htm
http://antiqueradio.org/restoration.htm
Regards,
Phil Nelson
Old 05-01-2011, 08:51 PM
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
Thanks for the articles. I read both of them before actually. I did run into one more thing. I actually ran into it when ordered my caps. There is one cap that on the photofact says 600v but the one that is installed is 800v. I ordered a 630v trusting that the photofact is correct but now I'm second guessing myself into thinking I need something over 800v.
Old 05-01-2011, 09:21 PM
Which cap is it (Sams part number)?
Phil Nelson
Old 05-02-2011, 03:44 PM
vts1134's Avatar
Looking For Time
I'm not sure to which part number you are referring. The parts list has an item number, which is C40. There is also replacement part numbers from-
Majestic- D03.100-12
Aerovox- P688-022
Centralab- DF-203
Cornell Dubilier- PTE6S2
Sprague- 6TM-622
The schematics state that it's used for audio coupling. Sams states .022mf capacitance and 600v voltage rating. The cap in the set is .02mf 800v.
Old 05-02-2011, 04:09 PM
I mean the part number given in the Sams manual (C40). 630V should be fine there.
Phil Nelson
Old 05-02-2011, 04:22 PM
vts1134's Avatar
Looking For Time
Why do you think there is an 800v in there? Could it have been repaired in the past possibly?
