Old 05-11-2011, 12:21 AM
Originally Posted by vts1134 View Post
For some reason the wire on the output side of the transformer is soldered on a "landing strip"(I'm not sure if that is what you really call it but that is what I came up with).
Could the next step be firing the set up and testing voltage out of the vertical output transformer(T4)?
Terminal strip.
Anyway, be careful with the vertical output tube plate, when it's working normally it has pulses about 1 to 2KV tall.
Before firing up the set, check that you have continuity on the primary of the vertical output transformer. Likely a few hundred ohms. Oh, on the yoke, getting continuity across the secondary either tells you the yoke has no opens or the secondary has no opens. Or both have no opens. You'll have to disconnect a lead on one of these to tell for sure.
