The next point should read +135 volts to chassis.It may be accessed at C148B positive connection. The voltage at the C147C positive should read -60 volts to chassis and the can of C147 should read -120volts to chassis. |
1st term (under trans) 202v 2nd term 340v 3rd term 0 4th term 15 5th term 31 measured in dc scale, black to chassis |
The second terminal which is supposed to be +135 volt measures 340 volts: is that correct? I assume you have changed the electrolytics. If the 135 volt line is so high, it may be that the wiring may be incorrect. Please check the wiring closely around these points. In addition, the -15 volts and -31 volts show the correct division ratio of about 2 to 1. (It should be -60v and -120v). This would imply that the other end of the divider is open or high resistance. Otherwise something is pulling down the -120v. Please check the wiring. |
