Old 05-16-2011, 02:22 PM
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
I found a Stancor a-8122 locally, it's a vertical blocking oscillator transformer and has a turn ratio 1:4.2. Any one venture a guess if it'll work?
Old 05-16-2011, 03:10 PM
VintagePC's Avatar
Tube bug got me 05/2010
Should do the job. The turns ratio that is key to the magic that makes it work.
The only thing you may run into is the polarity (I suppose "phasing" is a better term since we're dealing with AC) - if it doesn't work, reverse the leads to one of the two sides and try again.
I don't know what would happen if you got the phasing out of sync here - If it's part of an oscillator, then it probably wouldn't oscillate, but since it's part of the vertical section, you might also end up with an upside-down picture (either way, it's a "safe" mistake - things won't go bang if it's wrong)
