1946 Silvertone 6002 Midget
The smallest tube radio I have ever seen
I got this in a Antique/Thrift store in Humboldt, AZ where I have a modest country home. The lady turned it on in the store and it works but it had a HUM which I expected. In complete original condition. I got the schematic I pulled it apart and cleaned it up, then ordered the 8 capacitors to bring it back alive and safe You can see in the 2nd picture that it wasn't as clean as it is now I can get the correct cream colored knob from AES, right down the road 12SA7 - Converter 12SQ7 - 2nd Det. 1st AF 50L6GT - Power output 35Z5GT - Rectification Last edited by omegaman; 05-07-2011 at 10:13 PM. |
Nice!
![]() ![]() ![]() I have a couple of these that were made a little later, perhaps 1948 or so. By that time, they dropped the Silvertone logo across the top and eliminated the back. I think my parents paid under 10$ for my Blue one in 1948. Lots of good childhood memories...still works great! jr Last edited by jr_tech; 05-08-2011 at 12:49 AM. Reason: Add pix of my first radio |
Cute little radios. Betcha they were made by Arvin for Sears. If the model number has 132 in it they were. Q: how do they drop the last 12 volts in the heater string? Big resistor underneath?
Yeah, it looks like a double-first cousin to a couple of Arvins I have. Neat little sets. Won't outperform an R-390A, but they still do OK for what they are. I even have the prewar 2 & 3 tube versions.
Benevolent Despot |
I got it because it was tiny, tube and in great cosmetic condition
Since I usually get hugh honkin stereo consoles, the wife allowed this small purchase well...she didn't complain too much |
Schematic
Here is the schematic
Having the "War Dept." approve of one's hobbies is ALWAYS a Good Thing...(grin) And it helps if the item in question you wanted is small & cute like this l'il guy is...
Benevolent Despot |
They definately were made by Arvin. IIRC, the heater dropper resister was a 47 ohm@ 2watt. The metal four tube Airline TRF was made by Kingston.
Just look at those channels whiz on by. - Fred Sanford |
I got the new caps and did the recap job. The radio sounds great for a non Hi-Fi AM radio. All hum is gone. Tubes are nice and strong and the controls are now quiet
It does heat up the metal case pretty good since the tubes are like 1/2 inch from the metal cover, but hey that's tubes PROBLEM: There is an issue with the tuning, the radio only picks up half the dial. The upper half When I move to the lower end of the dial scale I can hear the vanes intercept and no stations. They touch and I can hear them like grinding? Any idea what to do? Should I try to separate the vanes? I will get some NON-RESIDUAL ELECTRICAL Contact cleaner and clean the vanes Then just a potent jot of fader lube in the vane shaft But it feels GOOD to spend 1 hour and 8 bucks to bring a HUMMING radio back to Earth in time for the end of the world on Saturday |
Yes you will have to carefully bend the bent plate back into position so there not rubbing. Most of the time it's just first outside plate. Wouldn't worry with cleaning just dust off with a paint brush.
Terry |
That was it
I used an x-acto knife and just carefully worked the vanes until I could see separation No more grinding and I now get reception on the full scale I think I will still get the cleaner and use it Thank you for increasing my knowledge base |
A good electronic cleaner for blasting out dirt is CRC Electronic Cleaner, widely available at auto parts stores.
Here is a picture after I recapped the radio
I use to take the effort to pull the old caps out completely but on this radio I just clipped the leads and pig tailed the new cap onto the old lead I also repared a small tear in the speaker Last edited by omegaman; 05-21-2011 at 10:06 AM. Reason: Add detail |
One thing to note about metal cased radios of this vintage. Sometimes the case is connected to one side of the line, so can be at 120 VAC potential, depending on how it is plugged in. One of our radio club members got a good shock by standing in a pool of water(at a local festival where we were displaying radios) and touching the metal case of a radio.
Be careful! Safety rules were not as strict as now. |
