Old 05-30-2011, 01:42 PM
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
I spent some time looking over the schematic to get familiar with things down stream from the vertical output stage. I traced each connection from point to point on the schematic and on the set itself and found my first mistake. I had connected the secondary of T2 to the wrong place. I connected it correctly and got this.
I also found the the ion trap was a bit out of place so I tried to align it as much as I could by site. I also adjusted the vertical controls to see if I could get an aligned picture but the picture above is as good as I could get it. I'm not sure if you can tell by the picture but the bottom of the picture is brighter than the top, and the left hand side of the screen is brighter than right. Any ideas on where to head next?
