#121
Huh. By golly that tube does not have an external aquadag coating. That wire around the HV lead has no electrical function, it's just a mechanical support.
At least you've located what's doing the arcy sparky thing. oc |
#122
It doesn't look to me like your CRT has any aquadag coating on it - not all do. I bet there's a high voltage capacitor next the the rectifier tube that does the filtering.
The arcing could be caused by component leads or wires coming too close to the base. I recently worked on a Motoorla that had bad arcing caused my a wire coming too close to the rectifier. All I had to do was move it out of the way. Did you do any work around that area ? |
#123
xxxxxxxxxxxxxxxx
Last edited by roundscreen; 06-19-2011 at 07:48 PM. Reason: Some one noticed it before I did |
#124
I did not. I'm almost positive that the arcing is happening inside the tube itself. I'll fire the set up one more time and be sure.
#125
#126
That is the first time I have seen a set with a glass crt that did not have a aquadag coating on it.
Ed |
#127
The arcing is coming from inside the tube, I'm sure of it now. The picture is kind of hard to see because the room was dark but you can see the bluish glow coming from inside the 1X2. Am I right in assuming that this tube is no good?
#128
Yep, it has air in it and the HV is causing it to ionize. Replace it, and get that HV all the way to the screen!
Evolution... |
#129
I have several early rectangular 16" CRTs with no coating on them. I'm not sure why though. The datasheets state that they should.
#130
Wonder why are they using a door knob cap in a set with a glass crt instead of using the aquadag for a path to ground? Ed |
#131
![]() Here is the new tube installed and waiting for a higher intellect to give it the green light.
#133
Yep, they should be interchangeable.
Take a look at the letter code specifications - the trailing letters indicate features of the tube. A/B/C are revisions that are backwards compatible, and there are a few others like GT, M etc. indicating glass tube, metal, and some other things. http://en.wikipedia.org/wiki/RETMA_tube_designation |
#134
Fired the set up and got this.
![]() Fired her down immediately. Is this normal? Just a burn off process or a symptom of another problem? |
#135
Holy mackrel. Possibly a dead short either in the doorknob cap or from the 1X2 filament winding to ground. oc
