Old 06-20-2011, 11:25 PM
ChuckA's Avatar
ChuckA ChuckA is offline
Anybody else notice the missing decals on the TV control side board? Also it looks like the board is mahogany rather than the tight grained walnut normally used, possibly replaced when tuner mod happened.
With all the dust can't tell if the radio side board has labels.
Looks to be a TRK-12 rather than a TRK-120, radio appears to have an eye tube, and the bottom kick panel looks to have the center open.
Biggest unknown is going to be the CRT, they can be rebuilt ($1000+), but a verified good one would make the set a lot easier to sell.
I think if I came across this set, I'd be inclined to leave the tuner in it. It's part of its history, the owners thought the set was worth spending a bit of money to update it and continue using it possibly into the late 40's or early 50's.
If you do end up with this set, the most important thing to protect is the CRT. If you aren't comfortable removing it then make sure the set is transported straight up, DO NOT let it tip over as you risk breaking the neck of the tube. If you do decide to remove the CRT, be extremely careful removing the high voltage cable on the CRT bell, over time this connection corrodes and if you pull on it you can pull the HV terminal off and run the risk of cracking the glass.
Looks like you will be upgrading your audio system - BIG TIME
Good Luck
Chuck
www.myvintagetv.com
Learn from the mistakes of others -
You can't live long enough to make them all yourself.
