#181
What still puzzles me is- he was drawing a healthy 'air arc' off the plate connector of the 1X2. Assuming the replacement 1X2 is good, there should definitely be adequate HV coming out of it.. assuming there is no short to ground. One remaining possibility is that the second 1X2 is gassy. So one question- is the 1X2 getting hot after a few minutes of running? If it's hot, like too hot to touch, it would indicate the tube's gassy (even though it might still test good on a tester). |
#182
I've only had the set on for seconds after noticing the problem so I don't know if the 1X2 is hot to the touch. I could test this theory if you think it's ok to leave the set powered up for that long.
#183
It should be all right, (and I'm sure you know this) but don't run it unattended. (and replace C61 before you do fire it up!)
I like to run things through a power bar so I have a kill switch on hand that's not near/on the set, just in case. Then, keep watching and listening for any funny business and kill it if anything else starts acting weird. Keep a good eye on the flyback and kill the power if it starts to drip wax! I should add that gassy tubes usually have a blue-violet flickering glow to them, which is in the _space_ inside the tube... What it looks like you have (and you can confirm this, since cameras don't usually do fluorescent colours justice) is a pure, deep blue coming from the inner layer of glass itself- that's entirely the fluorescent emission of the glass from being bombarded with high-energy electrons. There's a couple of videos on YouTube (heh) if you search "gassy tubes" that will help you distinguish between the two. |
#184
Rather (after replacing C61), do the 'air arc' test again. It will confirm whether the fly's putting out without loading it down. Now, if the fly's putting out, install the 1X2 with the plate cap connected, and remove the doorknob. This will avoid loading the flyback (in case the tube is gassy). If the tube is good, the HV should come up and light the CRT. If the 1X2 is gassy, it may fry the 470K resistor (R89) in series with the HV lead. R89 is thus "sacrificial" and takes the load otherwise borne by the flyback with a gassy 1X2. Much easier to replace a resistor than the flyback. |
#185
Yah, some tubes can glow pure blue and work fine. I have observed this in a couple of sets.
Purple, not so good. The photo shows a 5U4G rectifier in my RCA T-100 just before it failed completely. Definitely purple rather than blue. There was nothing wrong with the TV, that old tube just gave up the ghost. Phil Nelson
#186
I guess .1% wins this time. I found C61. It is a .05 instead of a .035 though. It was one of the black beauties and didn't have it's rating on it. It had the same marking bands as two other black beauties that were .05 though.
A few youtube searches on gassy tubes and I think this is what I have. The last two posts came in after I did the test so didn't have a chance to read the "don't do that" warning. The set was still only on for less than a minute. http://www.flickr.com/photos/23097242@N03/5873904324/ This will help make it a little easier to see what the tube is doing. The video is of the new tube. The old tube does close to the same thing, just not nearly as much blue glow. I suppose #3 could be the charm. Last edited by vts1134; 06-26-2011 at 01:34 PM. |
#187
Are you still hearing the hissing or spitting sound? A length of plastic tube held to your ear can help you pinpoint its location.
Phil Nelson |
#188
Killer suggestion on the length of tube though. I will definitely remember that for the future. |
#189
If the doorknob isn't causing the arcing, it could be the socket itself. Have you checked it yet? Carbon tracking on HV parts can cause shorts from seemingly nowhere, so make sure you inspect the rectifier tube socket and replace it if you're in any doubt.
Evolution... |
#190
Interesting thought. I'll inspect.
#191
http://www.youtube.com/watch?v=x7KK7bXJV2c
Evolution... |
#192
Tried this and it's not the problem.
#193
Most people here will coat the flyback with a "sensor-safe" silicone product (regular silicone produces ammonia or acetic acid as it cures, which corrodes copper). That will likely kill the arcing. A few wraps of PVC electrical tape might work in a pinch for testing until you can get the right stuff.
#195
At this point, I'd recomment replacing the filament winding for the rectifier and the doorknob cap. I often find filament windings have degraded insulation, and that's never a good thing around HV.
Evolution... |
