Most people here will coat the flyback with a "sensor-safe" silicone product (regular silicone produces ammonia or acetic acid as it cures, which corrodes copper). That will likely kill the arcing. A few wraps of PVC electrical tape might work in a pinch for testing until you can get the right stuff.
At this point, I'd recomment replacing the filament winding for the rectifier and the doorknob cap. I often find filament windings have degraded insulation, and that's never a good thing around HV.
Evolution... |
Got a good supplier for a 500pf 20,000v door knob capacitor?
Digi-key has a few... for example:
http://search.digikey.com/scripts/Dk...me=445-3890-ND http://search.digikey.com/scripts/Dk...me=445-2235-ND ... but they won't be cheap :S |
Well sunnava gun, so it was the doorknob all along, and now the filament winding is popping through. Some kind soul oughta send him a hunk of HV wire to replace that with, along with a doorknob.
So as I sit here and ponder I can't help but think that the door knob cap ISN'T shorted to ground. If that cap was shorted to ground it would certainly account for our problem, but could just a leaky cap cause our problem? If not could it be the ground side of the cap some how isn't grounded? Or some other problem other than the cap itself being bad. I just know that some times in my work when I think I've found the answer from trouble shooting I just end up "fixing" things that aren't broken and still not finding the real problem.
OK, did the CRT light up with a raster after you removed the doorknob? If so, it would pretty well prove the doorknob was at fault. Probably arcing internally since it measured open circuit on your ohms test.
Earlier you mentioned a "new arc" that's developed. I (probably erroneously) interpreted it to mean there's a hole in the insulation of the filament winding that's allowing a DC arc. That would be evinced by a loud, sharp snapping sound. If instead the "arc" is a bluish, lightly hissing corona discharge from the 'tire' to the filament loop, you may be able to insulate it with some silicone. Is it possible to move the filament loop further down on the frame, away from the 'tire'? Last edited by old_coot88; 06-26-2011 at 06:23 PM. |
