Old 06-29-2011, 02:24 PM
i have a sams but amazingly is says nothing about a 1k resistor, this is a mystery.
Old 06-29-2011, 02:28 PM
and there is nothing in the HV setup talking about how to check the shunt tube current?
look in the misc adjustments under horizontal sweep circuit adjustments, look for referece to the cathode current of the HV regulator tube.
Old 06-29-2011, 02:37 PM
yes there is but it talks about shorting certain terminals tuning in a picture then removing said shorted terminal and place a vtvm thru a hi vlotage probe to anode connector. them point H to ground, short across horiz ocill cathode coil pin 8 to ground plus more, boy this is out of my area, confusing there must be an easier way. but nothing about a 1k resistor.
Old 06-29-2011, 02:40 PM
thats to set the osc, there should be more about the cathode current of the horz out and the regulator tube, read it all...
Old 06-29-2011, 02:46 PM
after above it says to then adjust current not to exceed 210 but to set 200ma, with the meter in series with cathode lead on hot, on the horiz linearity coil the rest is focus,height,vert lin. no resistor.
Old 06-29-2011, 02:49 PM
nothing about HV regulation anywhere in the misc adjustments? does is say what the HV should be set to?
Old 06-29-2011, 02:52 PM
23.5-26.5 kv
Old 06-29-2011, 02:53 PM
hv should be somewhat the same bright up or down?
Old 06-29-2011, 03:04 PM
so somewhere in the misc adj it just says set hv to 23.5-26.5 with no other instructions, or are you just reading that off the schematic.
Old 06-29-2011, 03:05 PM
it says at the end of the above and then the other is agc, grey scale. the instuctions page .
Old 06-29-2011, 03:07 PM
ok then I cant offer any other help, I hope you get it figure out.
Old 06-29-2011, 03:11 PM
could all of this infact be a hot that was weak already and when i did the caps it finally went bad all together since trying a new one hv went right to 30kv but i dont thik i tried the adjust pot at that point so may ill trun the pot down befor power up then check the hv and see if it adjusts.
Old 06-29-2011, 04:23 PM
ctc17 ctc17 is offline
not to have to much stupid on my face that set has no 1k it has a current test jumper according to the schematic.
Old 06-29-2011, 05:58 PM
you could remove the jumper and put a 1k in there then measure the voltage drop accross the resistor or use a micro amp meter. You need about a 0-2 ma scale
Old 06-29-2011, 06:10 PM
that crt cathode wire to the focus rec is nothing unless i turn the bright down to get some voltage.
