Old 07-04-2011, 12:22 AM
Winky Dink's Avatar
Winky Dink Winky Dink is offline
Looked into the suggestions by WA2ise and old_coot88, and all that looks OK. I was about to follow up on Reece's recommendation of getting the signal with a loose link from the good set, but I got carried away with trying to learn what I was doing. Then the Frequency Fairy appeared and promised to put a signal generator under my pillow next week. Before I can use that, however, I need to know how to assess or measure signal or output strength. Is this something I can hear, or am I measuring audio output from the voice coil, or what? In case it might be useful, I have a 1960s analog Micronta multimeter with an output jack.
I've posted specs, alignment instructions, etc. in the last 5 or 10 images in this album:
https://picasaweb.google.com/coldrb/...eat=directlink
Viewing Picasa Web albums: (1) Click an image from the thumbnails. (2) Click "full screen" at top left. (3) Use navigation bar at bottom of image or use back button to return to album thumbnails. (4) If you're not in full-screen mode, a blue navigation arrow will appear if you move the cursor to the right or left of the image.
- Winky
