Originally Posted by vts1134
I have a 1X2B. According to my HV probe the 16GP4 is running at 14-15kv right now without the immediate sparking failure on the 1X2 which would be at 28-30kv PIV? It sounds like the 1X2 isn't going to last that long if I'm running it that far over spec. The CRT might not be happy running that far over spec either! One other thing that I have been pondering is what kind of X-ray emissions the 1X2 might be putting out with the voltage that high.
They list the maximum anode voltage for that CRT at 14KV. 15KV isn't going to kill it, but it doesn't help.
Does your probe have its own meter or does it plug in to your multi-meter?
old_coot88 is right about x-ray production only occurring during the positive going half cycle which causes electrons to bombard the plate. However, they don't even have half the PIV. The forward drop on these tubes is between 80-200 volts. The electrons only get accelerated to that energy. Those x-rays will never make it out of the 1X2.
If there was a failure of the 1X2 such that the forward drop was as high as half the PIV, then you'd have higher energy x-rays, but the cathode emission would be so low at this point that the x-ray dose rate would be very small because of the very low current.
