Originally Posted by damen
You were right about the flyback it's bad  not much hope for this set I guess now I see why the set had so little use and from what I read in other trends it is almost impossible to find a fly for one of these I also read only Zenith made the flys for these. I have to wonder if there was none available back in the day and maybe that's why it was taken out of service with such low hours. The fly in it looks barely used except for some wax on the bottom of the cage and the tubes in the cage are original and still look new not darkend and dusty like you see on other old sets. I seen that someone had checked with Moyers and they had none to.
Perhaps SOMEONE, somewhere, DOES have a "spare" 29JC20 flyback, .. that worked the last time it was fired (in 1989), maybe even in a nearly complete chassis.... hanging around unused.....
