Old 08-19-2011, 04:41 PM
maxhifi's Avatar
maxhifi maxhifi is offline
This TV has a strange problem where for the first 20 minutes it is on, everything looks great, but then after it is fully warm, the vertical linearity goes out of range of the control, to the point it can't be adjusted (top half of screen looks elongated). I am suspecting the electrolytic cap on the vertical output tube's cathode, or maybe some resistors drifting after they reach full operating temperature. I haven't yet got a schematic for this set, and will be unable to work on it for a few days.
Old 08-19-2011, 04:46 PM
bridging the electro is a quick try, also some cool spray on resistors and caps may point to the problem. I would suspect some resistors, check spary some of the high value you ones in the vert circuit.
Old 08-19-2011, 04:54 PM
maxhifi's Avatar
10-4, will give it a try on Monday.
