Old 08-25-2011, 02:06 PM
damen's Avatar
damen damen is offline
Originally Posted by DaveWM View Post
check your line voltage, if you have a variac see how low it can go before the width is a problem, check the cathode current at 117vac
I had it at about 117v when I did that test and I did go down lower and the cathode current went down I will have to play with it and see how low I can go with the line current with out problems.
