Are you using Sams or the original manufacturer's schematic. Often Sams does not use the same component designations as the manufacturer. If the component designations are on the PC board, it compounds the confusion. Sometimes values change do to engineering notices or production change.
Either way, if a unit worked at one time and simply failed, no bungled repairs, you are usually safe replacing with the same value as you take out. |
