Apparently it was never intended to be taken on and off often. It's only those little tabs that cause the press fit. But boy do they ever hold while its all originally mounted in the cabinet.
That bottom J has the glass pressed up against the backside. So possibly those tabs create more of a cam mechanism, so as to allow the trim to rotate around the retainer for removal. I don't know how else to explain it. It holds when it's on the cabinet, but looks pretty confusing while it's off.
