Old 08-27-2011, 12:30 AM
What I don't understand is why the RCA field service manual is so vague on the removal process. I'll bet they sold a lot of replacement brass trim over the years.
Old 08-27-2011, 01:14 AM
So, if I'm following all this . . . the top trim (U channel) piece can be removed without removing anything else, but to remove the bottom one for a swap, I would need to remove everything, including the glass.
Are the top & bottom pieces even interchangeable? This is looking like more fuss than it's worth, especially since my glass doesn't look dirty in the first place.
Phil Nelson
Old 08-27-2011, 11:22 AM
Can't say I tried removing the bottom with the glass on, but I think it will be much easier working from the top first. Also, you can't take the bottom retainers off to remove the glass for cleaning.
Phil Nelson
They are interchangable.
Old 08-28-2011, 10:45 AM
That's why RCA always tried to sell service contracts with their sets. They used to have those clips inside, all around the CRT. Another PITA, those tuner indicator belts.
