Old 09-03-2011, 08:29 PM
Using the IF of an analog VCR to convert 100MHz FM to feed 45MHz FM set
One way to block convert the modern FM broadcast badn down to the old 45MHz FM band is to use the IF output of a VCR's analog cable TV tuner. Here is a closeup of a typical tuner module found inside a newer VCR. You want to connect a coz lead to this "IF out" pin of this module. Best use a 0.001uF cap to avoid any DC loading issues. This coax will feed your old prewar 45MHz FM set. Tune the VCR to cable channel 97 (which is located in the same frequencies as the FM broadcast band). And connect an antenna to the VCR tuner input F connector. Now you should be able to tune in regular FM radio stations. Note that stations that are higher frequencies will tune on the 45MHz as lower frequencies.
Old 09-06-2011, 05:56 AM
Reece's Avatar
Reece Reece is offline
This is a great idea. On sets with not much room, should be able to excise the board from the VCR and install in the radio cabinet. I'm sure there are tricks I'm not aware of that would be required in such a case to keep the board alive away from the tape mechanism.
Reece
Old 09-06-2011, 02:17 PM
Originally Posted by Reece View Post
This is a great idea. On sets with not much room, should be able to excise the board from the VCR and install in the radio cabinet. ...
There would be difficulties, if the tuner is digitally controlled by a micro that also receives the remote control signals. These control signals are usually serial bitstreams, and would be hard to fake. What I'd do is just put the VCR elsewhere in the room, and run a coax cable from the tapped IF to the 45MHz FM radio.
