Yep, everything is set up right and I have equal peaks on the wave coil. Quote:
The line moves opposite of the picture. That means it's not a drive thing? Quote:
Evolution... |
The one white line is probably a video overshoot meaning that the perhaps a sync pulse edge is causing the line on retrace. The multiple lines to the left of it are the individual cycles of burst. The overshoot will generally be due to IF alignment or if the fine tuning moves the video carrier too far down the Nyquist slope. Do you see the line with the video injected at baseband? I have seen the line made more obvious if the CRT RGB screen adjustments are set too high: they have to be set to ensure the beam current extinguishes on retrace. Quote:
Since it's not a vertical blanking issue, how exactly does this chassis blank horizontally? I don't see a blanking tube.
Evolution... |
Try adjusting the fine tuning and reduce the RGB CRT screen adjustments. Last edited by Penthode; 09-18-2011 at 05:46 PM. |
Here's a scope trace, maybe you can get something from it.
Bottom is the composite output from the generator, top is from the grid of the second video amp tube. It does look like there's some fuzz on the blanking pulse, like the whole signal slid over a little. If so, are we talking sync issues or IF issues?
Evolution... Last edited by miniman82; 03-01-2012 at 11:46 PM. |
Also the broadcast sync waveform had a carefully controlled rise and fall time to help reduce this effect. Your test generator might have too fast a rise and fall time which may cause problems. Your modulator, like most consumer modulators, is double sideband so that should not cause a problem. If your IF response is not flat or if the video carrier is too low on the Nyquist slope of the VIF response, this could lead to the white line appearing. I have attached a jpg photo I found on the web to illustrate what I had expected the sync to look like as applied to the CRT. Your waveform seems to have very fast rise/fall time sync pulses. Try expanding the waveform around the sync fall as an overshoot there may be seen in the video as the white vertical line. Are you injecting at baseband or RF input? If at RF, if you adjust the fine tuning control to raise the video carrier to the top of the Nyquist VIF slope (that is adjust until you begin to lose picture detail and color and picture starts to smear) see if the line diminishes. Lastly, consumer DTV boxes have proper broadcast sync rise and fall times so see if another video source causes problems. Last edited by Penthode; 02-26-2025 at 08:42 PM. |
