Old 09-22-2011, 06:42 AM
Reece's Avatar
Reece Reece is offline
Electronic M is right, you need to keep the three tuning caps in about the same position. Put a strong local station on another radio and look at how the tuning cap is meshed. Then put the three tuning caps on the Stewart Warner in the same position and try. Each will have to be tweaked to max the signal.
This hassle is why the mfrs. worked so hard to get one-knob tuning!
Reece
Old 09-22-2011, 04:12 PM
stusnyder's Avatar
I'll try it tonight, thanks for the tips!
Old 09-23-2011, 03:47 AM
stusnyder's Avatar
I checked it out more last night and it seems like one of the transformers is not getting power to it.
Old 09-23-2011, 09:19 AM
Sometimes the rosin in the solder used back then was a bit corrosive on the fine copper wire. Sometimes careful resoldering to bridge the break might fix it.
Old 09-23-2011, 08:01 PM
stusnyder's Avatar
Worked on it tonight, I do have power in and out both transformers. Checked out everything else and did not find anything obvious. 2 capacitors in entire radio. No value listed on them or in schematic. Anyone know what value are these?
Old 09-24-2011, 07:28 PM
leadlike's Avatar
leadlike leadlike is offline
Caps are typically 1 or 2 mfd, rated for a couple hundred volts DC. On these 20s radios, typically you'll find the interstage transformers open. There are replacements available-I believe AES sells just the bobbin and windings so you can use parts from your old tf to keep things looking original. You can also bypass your tfs with some common value caps and resistors. I think the Philco repair website has a how to on that.
Old 09-24-2011, 10:03 PM
stusnyder's Avatar
I did some checking on it tonight, it seems like one transformer is open.
