Zenith "Graemere" porthole scored
I picked up this Zenith G2346R 12" porthole set a couple days ago just across the Wisconsin border.
The cabinet appears to has identical styling to my 16" Monroe set, but it's 20% or so smaller. I plan to restore both, but one will have to go after that. ![]() Missing a few small knobs. ![]() I pulled a few tubes and found numbers like 19BG6 and 25AX4 so I figure it must be a series wired set, but what's that huge transformer for then ? I dug up a schematic and found that it is indeed a series filament hot chassis set, but the B+ and 5U4 are power by that big transformer. The label inside indicates this model came with either a metal cone 12UP4A or an all glass 12LP4A. This has the 12LP4A and it appears to be original. It has a wacky ion trap magnet composed of two magnet rings mounted on a brass sleeve. ![]() The flyback looks to be in decent condition. The seller claims he powered the set up and got a raster with about two inches of vertical height. I tried testing the CRT but had trouble with intermittent contacts in the loose base. The readings I did managed to get were deep in the bad zone though I'll unwrap the electrical tape holding it on and try to fix it up. ![]() I'm inclined to keep this smaller porthole set, but the 16" is more impressive and does not have a hot chassis ![]() The seller also had an Admiral 16R12 for $10 with the original metal back and intact pencil box door so how could I refuse ![]() I did a little research and found out the the brown bakelite set is the 16R12 and the black version is the 16R11.
