Old 11-30-2011, 02:22 PM
kx250rider's Avatar
REAL TVs have TUBES!
The law suit RCA vs. Zenith; 1953 stolen technology
I'm trying to get to the bottom of a rumor (actually several) which I've heard over the past 20 years, on the subject of exactly what happened between RCA & Zenith when Zenith put out the prototype 43M20 color set.
The tube in the Zenith was basically an identical copy of one of the RCA prototype tubes with the screw heads showing in the mask. It's my understanding that Zenith got hold of that design, and had Rauland build it "slightly without proper licensing". Consequently, a suit was filed, and Zenith lost. The result supposedly was the long delay (til at least 1961) before Zenith came out with a color TV.
Rumor #2, is that Zenith had to swear to recall and destroy all of those 43M20 sets as of December of '53, but since I know of at least a couple of them existing today with the original screwhead tube, this didn't happen. One of them I know was stolen from the lobby of the Biltmore Hotel in Oakland, CA from where it was on public display. It is still in California.
Does anyone have any case info on this, or is it all a bunch of made-up hooey? I don't know much about legal case research, so maybe if there's a paralegal or lawyer among us, would it be possible to find the case? No idea of dates or actual names on it.
Charles
Old 11-30-2011, 03:11 PM
I dunno, but from what little you relate here, sounds like it'd be a DAMN good story. The emnity between Sarnoff & McDonald, & their respective companies was palpable-Reportedly, The General & Cdr. McDonald could barely stand to be in the same room w/each other...McDonald was a patrician WASP type, & Sarnoff...Well, he WASN'T. (grin)
Old 11-30-2011, 05:00 PM
electroking's Avatar
a- v- karma member
I did not find anything about that particular conflict, but I came across an interesting
paper:
E. W. Herold, 'A History of Color Television Displays', Proceedings of the IEEE,
vol. 64, no. 9, Sept. 1976, pp. 1331-1338.
Any large university library should have this available for reading on line. Good
luck with your request.
P.S.: here is some possibly useful related info.
The author of the above paper acted as an expert witness in at least three
court cases, but unfortunately not the one you are referring to. See this link:
http://www.davidsarnoff.org/ewh-appendix01.html
Other link about Herold:
http://www.davidsarnoff.org/ewh-editorialnotes.html
Last edited by electroking; 11-30-2011 at 05:13 PM. Reason: added note and link; added extra link
Old 11-30-2011, 05:23 PM
Well I know that Zenith waited untill about 1948 to make consumer TV sets so they could make the best ones on the market....I sort of assumed they just did the same thing when color arrived, but this rumor is makeing me think otherwise.
Also I think that the Zenith 15" prototypes used the 15HP22 which was their electromagnetically converged variant of the 15GP22(which RCA created, and was ELECTROSTATICALLY converged). I assumed that RCA was fine with them experimenting with the modifications of their CRT in hopes of advancing color TV, but now I wonder....
Old 11-30-2011, 06:00 PM
Steve D.'s Avatar
Steve D. Steve D. is offline
Charles,
Perhaps the Ventura County main library has the N.Y. Times index for 1951,'52 '53. Or what ever year the suit may have occured. This would list all articles published in the Times for that year. Items are listed alphabetically. ie: Color TV, RCA, Zenith ect.
-Steve D.
Old 11-30-2011, 06:29 PM
You could also ask a librarian at the reference desk to help you find likely sources. I have had good luck that way, when I was able to get a librarian interested. (Much more interesting question for them than 13-year old kids wanting help with homework.)
Phil Nelson
Old 11-30-2011, 08:20 PM
Huh? Are you sure of that? The early tube manuals that I have show that both were electrostatic convergence (and had the same base connections). The difference being that the HP22 had the phosphor dots on the curved faceplate, rather than on a flat plate inside the jug.
Old 12-01-2011, 12:35 PM
kx250rider's Avatar
The one I saw, had the RCA type convergence and flat phosphor plate. In fact to test the tube, the former owner drove it with a CT-100 chassis. I think I read something about another earlier Zenith prototype with a different tube, but the 43M20, I believe, was a pre-production prototype (to go to market virtually as-shown at some point), similar to the RCA Model 5, which had very few changes when it became the CT-100.
Charles
Old 12-01-2011, 10:55 PM
John Folsom's Avatar
The Zenith 15" color sets came with RAULAND built versions of the RCA 15GP22. RCA was eager to license the CRT design to other manufactures, so it would seem unlikely that there would be any dispute over a Rauland built version. But I don't have any knowledge of legal issues one way or the other.
The 15HP22 was built by CBS-Hytron, and used the same electron gun and convergence scheme as a 15GP22, but had the phosphor dots placed directly on the faceplate of the CRT, with a curved shadow mask behind it. The RCA design 15GP22 had a flat phosphor dot plate with a flat shadow mask behind it. RCA was obliged to spend a million dollars for rights to the Hytron invention, and used it to produce the 21AXP22. To my knowledge, Hytron only produced the 15HP22 and the 19VP22 (which used magnetic convergence). I wonder if RCA bought exclusive rights to the Hytron dots-on-the-faceplate/curved shadow mask invention? Or did Hytron just get out of the color CRT business because they could see that the immediate business prospects for color TV looked grim?
John Folsom
Old 12-02-2011, 01:38 PM
kx250rider's Avatar
Oh boy; talk about asking the bully for his own lunch money
I'm thinking based on a faint recollection of something I read, that RCA licensed the 15GP22 design to Zenith for research only, and that Zenith was to have a royalty agreement in place with RCA PRIOR to contracting to build it for marketable sets, and they jumped the gun. Something like that.
Charles
Old 12-03-2011, 12:11 PM
cbenham's Avatar
cbenham cbenham is offline
So CBS actually designed a better Color CRT than RCA?
Then who, in reality, won the technical color race?
CBS.
[No blue bananas here, only bright yellow ones!]
Old 12-03-2011, 03:07 PM
ohohyodafarted's Avatar
Bob Galanter
My take on this from a business point of view is that CBS was smart enough to understand that their superior patent for placing phosphor dots on the inside face of the crt using a photographic process with colimated light source, was more valuable if sold to RCA, than if they had tried to market color tv sets. I would imagine that CBS understood that even if they had played hardball against RCA and refused to license or sell the CBS patent, that the public was not ready to spend big dollars to own a color tv set. And because patents only have a life of 7 years, eventually RCA would be able to use the process that CBS invented free of royalty any way. So why hang on to a patent that dosent make you any money. So CBS sold it to RCA and put a million bucks in their pocket while RCA invested and lost many millions of dollars for many years trying to promote color television.
CBS may have lost the color wars on the starndards issue, but in my eyes they were the ones that won the color war based on superior color crt technology.
I was down at John Folsom's a few weeks ago and we were working on the CBS set with the 19VP22. I gotta tell you that it has a "KNOCK YOUR SOCKS OFF" picture that makes a CT100 look pretty shabby in comparison. We're talking full gamut phosphors deposited directly on the face of the crt, and dynamic electromagnetic convergence that works very well. I think if CBS had the financial resources and the desire to block RCA and run with it's crt patent to compete against RCA, I think CBS would have been considered the company that brought color tv to the masses and not RCA.
But in the end it's always about the money. He who has the deepest pockets and can weather the storm for the longest, usually is the winner. RCA won because it had very deep pockets and they were willing to lose as much money as necessary to win the color war. Thankfully we still have examples of the 19" CBS set to demonstrate how far out in front of RCA, that CBS actually was. OF course this is just my opinion, but I think that most any collector who was to see the 19" CBS set in person would agree, that it runs rings around anything RCA had to offer.
And in the end nobody really knows what went on behind the scenes of the negotiations for RCA to obtain the CBS patent. In all likelyhood, RCA had patents on circuits and demod techniques which were used as a wedge against CBS to convince CBS to sell the CRT patent to RCA. Sarnoff was a ruthless business man and he would stop at nothing to get what he wanted.
A good example of the "better mousetrap" was the fellow that invented the intermitant windshield wiper that Ford Motor Co. stole. It took that poor fellow many years to fight against Ford and to finally be vindicated. IN the process it pretty much ruined his personal life. My guess is that CBS knew what they were up against in dealing with RCA, and CBS made the only smart business decission they could make. And that was to take the money and sell the patent to RCA.
John Folsom has a lot of very rare color sets. There isn't a single one in the bunch that isn't ultra rare and super desireable. But when it comes down to the nitty gritty, I would have to vote for the CBS 19" color set as being at the top of the list for performance and quality of craftsmenship. I think CBS knew what a wonderful CRT they had produced, and I think they wanted to market a set that would demonstrate the ability of that CRT. CBS spared no expense in producing this set. Every last detail says "high quality and expensive" From the service man oriented, dual chassis design with up front service controls and the removable CRT truck to the massive cabinet made from, thick, solid, heavy materials, this set says "CADILAC" in every respect. You've got to see it to understand.
ME http://AntiqueTvGuy.com
Old 12-03-2011, 05:50 PM
Steve McVoy's Avatar
Interesting observations about the 19VP22. I am not impressed with the picture on our Motorola with the 19V, and find it worse than the 15G sets. Maybe a difference in the quality of the CBS set vs. the Motorola.
Old 12-03-2011, 06:04 PM
Did Motorola ever produce a color set with a decent picture?
I remember in the 70's working on some of their 1960's & 70's sets and they seemed pretty awful then.
Old 12-03-2011, 10:27 PM
CBS selling that process sounds like a very, very wise business decision to me. Paley would live to see RCA crumble and be parted-out while his company kept trucking along.
Motorola always struck me as a company with some real smarts, but no concerns in the end about having the best performing TV on the market. Their tube-chassis color sets seemed to have been designed to a price point more than a quality level. Might be interesting to hear what the resident Motorola engineer has to say about that
