Old 12-28-2011, 12:56 PM
Originally Posted by Kamakiri View Post
This brings up an interesting point. What was the meaning of the numbers in the diagram? While they may be measurements of some kind, one can only imagine that it's actually a points score for a TV based bean bag toss
I believe that they define the resolution scale in various parts of the "wedges" from 200 to 450 lines in the center and 200 to 350 at the corners
Old 12-28-2011, 02:28 PM
Yes, resolution in "TV Lines per picture height." 330 lines is the most you could get on a broadcast signal with a black and white set (or color set with comb filter). Maybe 270 lines horizontal with a color set with 3.58 MHz trap.
Old 12-28-2011, 05:37 PM
W.B. W.B. is offline
NBC, oddly enough, had a layout of their famed "bullseye" pattern in which they explained what the significance of the wedge calibration dots as positioned on each side of their horizontal and vertical wedges, were:
Alas, I haven't heard, seen or read anything about this variation being seen on the air.
NOTE: 200 TV lines = 2.5 MHz (or "mc," as it was known as of 1947).
