Early 60's Silvertone CTC 10-11?
I went to Victorville today to pick up a late 50's Magnavox B&W console, it was $25 so I figured what the heck.
The seller told me ealier that he had a big Silvertone Color set also and that it was a tube set, I figured it would be an early 70's model perhaps but no, it's a Roundie! Not sure exactly what chassis is is other than an RCA clone, it has the two knobs under the channel changer and four across the bottom under the speaker, it also has a Safety Glass so it should have an unbonded tube, original I think because it has the Silvertone logo on the base. It checked weak right off but I let it cook for a few minutes and it went way high in the good range, it stayed in the good range after I dropped the voltage to 5v so I think it'll be OK. It's missing the back and the knob, the plate behunds the knob is beat up and the cabinet is rough. I'd like to restore it but if I can't at least find the knobs I'm not sure what I'll do with it. The odd perspective in the photo is because the set is standing on it's head. Last edited by Eric H; 01-24-2012 at 10:56 PM. |
Gonna guess CTC-11, Ed's site doesn't have a 10 matching that description.
Evolution... |
I don't know for sure but all the non-remote 10's seem to have the same knob layout?
Could still be an 11 of course. http://novia.net/~ereitan/Gallery/CTC10_Gallery.html |
One RARELY even sees color Silvertones close to that age, you ought to restore it or pass it along to some one who will.
Tom C. Zenith: The quality stays in EVEN after the name falls off! What I want. --> http://www.videokarma.org/showpost.p...62&postcount=4 Last edited by Electronic M; 01-06-2012 at 07:50 PM. |
It has the number dial behind the plate so I'm good there, no selector or fine tuning knobs though, all the other knobs are here. The trim plate is bent outward, haven't looked at it closely but it can probably be fixed and glued back down. No back, well something can be constructed for that, very slim chance of finding one because as mentioned, Silvertones are few and far between. If I can get it out of the van I'll hook the Variac to it and see what I get. |
Here's a Silvertone that was on ebay years ago... same looking 11-layout. The date of this file is from 2003.
The photo isn't that great, so I don't know that you'll be able to make the channel selector out. I wonder if one of our members won this auction.
Charlie Trahan He who dies with the most toys still dies. |
Thank you Charlie, it's pretty fuzzy but I can see it has a pointer shape to it.
If anyone here has a Silvertone of that era I'd really appreciate a high resolution picture of the knobs! |
i have this silvertone here in the pic but i doubt its what your looking for. its 1963. what year is your from.
Not sure, 60-62 I think.
Well this set is in better shape than the Magnavox, it at least has some life signs.
I took the Variac out to the Van and powered it up, started getting sound at 80 volts so I ran it up to 115 and the HV crackled to life along with a nice bright line (turned the brightness down quickly). It was only drawing 1.7 amps @ 115 volts with no hum. I'll have to bring it inside, probably piece by piece since it's too heavy to handle alone, that'll give me a chance to clean it up too. The dial cover looks like it can be fixed reasonably well, one of the small knobs appears to be incorrect also, probably the one without the brass insert. Last edited by Eric H; 01-07-2012 at 07:41 PM. |
I have one of those in the garage with a weak crt and trashed cabinet. (I think its the same)
Heres the video of it, starts at 3:30 http://www.youtube.com/watch?v=tEy5QAPaueI The chassis is like new and works perfect. Let me know if it would work for you. |
I have a very clean chassis but the knobs, Grille Cloth and the Silvertone rainbow logo are all pretty tired looking. Did it have a back by chance? I'll P.M. you soon. |
Im almost positive the back is on it. If you can use it to make a good set, come get it. Let me see if I have the sams for it. It is an 11
Im going to email you the sams so you can get that vert issue fixed Last edited by ctc17; 01-07-2012 at 09:06 PM. |
Do ctc-11's have a service switch? That could be the issue. Either dirty or switched to service. I don't have an 11 to know if it does but I know 9's do not.
"It's a mad mad mad mad world" !! http://www.youtube.com/user/mwstaton64?feature=mhee |
Yes it has a service switch. It also has the 1500 ohm resistor between b+ and the vertical out primary that likes to go open.
It has a thermistor in the b+ that limits the current inrush. If that went open and was bypassed, the current rush though the 1500 ohm vert resistor to the 80uf cap will eventually blow it open. |
