Old 01-09-2012, 07:57 PM
Originally Posted by Phil Nelson View Post
The CRT is stamped 15GP22 (and PAR under that, whatever PAR means).
Unless somebody knows what PAR means, we could guess - here's mine:
Production Acceptance Run (?)
Old 01-10-2012, 09:49 AM
Pete Deksnis's Avatar
15GP22 demo @ ETF 2007
Interesting guess. Phil: is there a date code on the 15GP22? The earliest known by me is the fourth week of 1954. If this tube is earlier it could be quite a significant 15G.
Pete
Old 01-10-2012, 01:10 PM
All I can see is the CRT neck at this stage. Nothing else printed on the glass of the neck. On the base it says Made in U.S.A. 5-22.
I just noticed that someone wrote in pencil on the bottoms of two guns. One says 5/13, the other has an asterisk drawn on it.
Phil Nelson
Old 01-10-2012, 04:26 PM
Some 15G's have production id numbers etched inside, but I've never seen pencil before. No contamination issues apparently.
Yes, it's a 'new' 15G. Not many around with 1955 date codes. As was speculated before, this may be either selected or, considering the inside dates, custom built for a TM-10.
Pete
Old 01-10-2012, 06:17 PM
So, the date code is something like year-week (5-22 being 1955, 22nd week)?
It didn't occur to me that the penciled numbers would also be a date code.
If I get some time later, I can look inside for etched codes.
Phil Nelson
P.S. New is good for me, from a customer standpoint. The last thing I want to buy is the first example (of anything) off the assembly line
Old 01-10-2012, 06:36 PM
kvflyer kvflyer is offline
That would be my guess too...
Old 01-10-2012, 10:29 PM
MORE DATE CODE Stuff...
That is so -- for RCA in the fifties. What ticks me off is when, in the next decade, RCA went to letter date codes for their 7- and 9-pin tubes.
As some of you know, I am slowly working on a 1956 Philco model 22D5102 color set with the TV-233 chassis. In the set, a Philco-branded, SYLVANIA-built 6AW8A date code -- for the 30th week of 1958 -- is "58 30", with the 58 stamped above the 30. However, a PHILCO-built 6M3 damper in the same set is stamped "249". I speculate based upon the history of the TV-123 in question that it stands for the 49th week of 1962.
Pete
Old 02-06-2012, 06:12 PM
Working at my usual snail's pace, I have gotten as far as easing the monitor onto its (protected!) face, so's to remove the CRT and get a peek at the nether bits. Looks pretty clean and unmolested underneath. I like that orderly layout.
After counting electrolytics (46) in the parts list, I decided to make a spreadsheet for ordering parts and keeping track of things that I replace.
Phil Nelson
