Old 01-15-2012, 02:01 PM
omegaman omegaman is offline
Can I power up my radio without the speakers connected
I have my Grundig 8058 on the bench and I need to power it up to measure voltages.
How do I safely power up the amp with the speakers not connected and NOT damage anything?
Any knowledge shared would be put to good use.
Old 01-15-2012, 02:05 PM
mstaton's Avatar
mstaton mstaton is offline
"Book em Dano!"
Use a 5 or 10 watt resistor with the same impedance as the speaker. The radio wont know the difference
Old 01-15-2012, 04:01 PM
bob91343 bob91343 is offline
If you keep the volume low you don't need a load.
Old 01-15-2012, 04:03 PM
Speaker connections
Here is a image of my speaker connections
Standard speaker connections are pretty self explanatory, but this setup...
How would I connect 10 watt 5 ohm resistors to this socket?
Old 01-15-2012, 04:47 PM
Reece's Avatar
Reece Reece is offline
Connect your resistor across the contacts that go to the woofer.
Reece
Old 01-15-2012, 07:35 PM
In the MUTE position the woofer is disconnected so apparently the company felt that no load was an acceptable condition. So I wouldn't worry about it.
Old 01-15-2012, 08:57 PM
That sounds logical
Old 01-16-2012, 12:35 AM
mstaton's Avatar
"Book em Dano!"
You can use the external speaker socket
Old 01-16-2012, 05:44 AM
Reece's Avatar
I saw that but posted the resistor anyway!
Reece
Old 01-31-2012, 09:15 AM
altbrewer altbrewer is offline
The mute position does not actually remove the speaker from the circuit. It puts L31 in series with the speaker.
Looks to me that it would be okay to put the resistor across the terminals for the external speaker, keeping the volume low.
Old 01-31-2012, 09:25 PM
The MUTE button does not appear to function if it is supposed to cut of all sound
It is more like the LOUD button on more modern stuff, or the contour on Harman Kardon
I just hooked an external speaker up
I just powered it up, volume off, long enough to get a plate reading off of the EL95's
246vdc and the spec calls for 260 so good enough
