Old 01-24-2012, 09:34 AM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
Since the set works well otherwise, I would look at electrolytic capacitors in the power supply. There is no circuit breaker inside and the relay is likely alright. It is most likely a capacitor issue if the set is old. Also check for bad solder joints around the power supply components. That should give you enough to get started.
