RCA console cabinet
with tuner and controls still attached. Missing chassis was a ?
http://stlouis.craigslist.org/atq/2818522536.html |
Looks more Zenith-y to me.
Evolution... |
I think it looks GE-ee-ee myself....
tvontheporch.com |
The round woofer and the vertical channel knobs don't say quite say Zenith to me either....and there's a script on the lower portion of the CRT bezel.
I think so too, and I think I have that identical model. Mine has a busted CRT neck, and I think the top finish is water-damaged. I can't remember. Too bad the distance is so far, or it might be worth one of us getting the other, and have one nice set.
Charles
Collecting & restoring TVs in Los Angeles since age 10 |
GE or a clone? If someone had a good chassis/crt but junk cabinet, it wouldn't matter much the brand, you could make it work. Sorting out all the control panel components vs. your chassis would be a challenge but I think it would be kinda fun.
Bryan |
'63 - '64 Zenith ?
Most likley not a Zenith.
I only looked at the bezel, so I'm sure I pulled the trigger too fast. The tuner does not look like a Zenith at all. Maybe a CTC 10/11? Maybe not.
I just emailed the advertiser. I will post the answer if/when received. Phil |
I also say GE. See attachment
Close, but no cigar. The bottom row of controls is different, and so is the right hand grille.
Evolution... |
The GE clone sets I saw all used an RCA bezel with the General Electric emblem in place of the New Vista Color emblems (or whatever RCA was using at that time). I've seen at least one model where they purposely installed the RCA bezel upside down and put the GE emblem on top. Since some of the RCA's had the emblem in the middle this could still be a General. As for the controls, could be difference between a CTC-11 & 12.
Bryan Last edited by bgadow; 01-29-2012 at 10:07 PM. Reason: syntax |
Mine's a CTC-12 clone, except for the tuner.
Charles
Looks like this will have to remain one of life's mysteries.
No reply after repeated attempts. Phil |
this is a GE,
this is the second time it is listed and I talked to the guy last time. he confirmed it was a GE, he sent me a few other pictures. D |
