Old 02-05-2012, 03:19 PM
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
It sure looks like a huge power supply ripple. The bars not rolling would be the case if the B&K's vert sweep is locked to the powerline (whereas a TV station's vert is offset slightly, which would cause the bars to roll). Possibly one of the replacement filters has gone open.
If you've got an extra 'lytic cap of equivalent rating as the main filters, you can jumper each one and see if the ripple disappears.
Or alternately if you have an analog AC voltmeter, you can measure ripple. Just put a cap of .1mf or so in series with the meter's hot lead (to block the DC component). I'm not sure i would trust a digital meter in that application.
I did try adding a cap to each of the electrolytics except for the 1,000mfd cap as I do not have a replacement for it.
How would I measure ripple with an analog meter? I have an analog VTVM and a .1mfd cap. That is to say what would I look for?
Old 02-05-2012, 05:49 PM
Originally Posted by vts1134 View Post
I did try adding a cap to each of the electrolytics except for the 1,000mfd cap as I do not have a replacement for it. How would I measure ripple with an analog meter? I have an analog VTVM and a .1mfd cap. That is to say what would I look for?
First i think it'd be a good idea to see perzackly what's connected between the center tap of the power xfmr and ground. Some of those filters' negative sides are insulated from ground and are connected to the CT. Just for the heck of it, take a resistance reading from that CT to ground. How much resistance does it show? If by chance it's inadvertantly shorted to ground, there would be some hairy ripple and hum bar effects.
In that pic of the power supply area that you posted earlier, it doesn't show where the center tap goes to (kinda fades into the twilight zone). Is it possible you could post a pic showing more of that area?
Old 02-06-2012, 07:47 AM
vts1134's Avatar
Looking For Time
I've got some readings on the electrolytics and a better picture of the schematic.
There are 5 multi stage electrolytic capacitors in the set. Towards the top of the picture, just above, and just to the right of the vertical centering control you can see two sections of C116. The negative on this cap reads shorted to ground which according to the schematic is correct. The other four caps are isolated from ground. Coming right off the center tap of the power transformer is the negative leads of C127, C128, and C131. Further along the line you have C132. Rather than give it away, how would I read the schematic and figure out what resistance reading those four caps should have to ground?
Old 02-06-2012, 11:40 AM
Hmm.. so the power xfmr CT is the negative voltage source*, supplying 110V negative for stuff elsewhere in the chassis. And the main filter for it is the 40mf.cap (square symbol). Can't read it too good, but i b'lieve it's C128A). The positive side of this cap should go to ground. Is this wired correctly? If it's not, the negative supply would have a large ripple on it. So check this first, and then check for ripple. And verify that there's 110V negative on it (+/- 10% or so).
To check resistance of the -110V source to ground, just look for a DC path to the nearest ground symbol in the schematic (hint: it goes thru the ion trap coils), and add up the values of the resistances in that path. And see if the sum agrees with the ohms reading you get on the meter (+/- 10% or so).
*This technique is called "back biasing". You'll find it used in old equipment quite often, particularly in 30s radios. The CT of the power xfmr winding, instead of going directly to ground, goes through a chain of resistors or a large tapped resistor to form a voltage divider, supplying negative voltages for biasing other tubes in the set. A Google under "Back bias voltage" should turn up some good info on it.
Old 02-06-2012, 05:40 PM
vts1134's Avatar
Looking For Time
Such an easy answer to my question. Seems silly that I had to ask, but now I know. All of the resistance readings on the negative sides of the capacitors read correctly.
This is wired correctly, and there is -110v present.
I believe that I am checking for ripple, but perhaps I have the test wrong. I have put my meter on an AC 4v scale. I've connected the ground lead to chassis ground and the probe through a .1mfd cap to negative on C128. Is my test correct, and am I seeing ripple on the meter?
http://www.youtube.com/watch?v=b5BBxQlqp1o
Old 02-06-2012, 07:40 PM
Yes your hookup is right. It's showing just a little over 2VAC of ripple. That shouldn't be anywhere near enough to cause the huge hum bar effect you're seeing. This pretty well eliminates the negative supply as the source of the problem.
So check for ripple on the positive supply, first on the 'upstream' side of the spkr field* coming out of the rectifier (there'll be a large ripple here) and then on the 'downstream' side (top of C127A). Then at the top of C116B. The ripple should smooth out to just a volt or two and get progressively smoother the further downstream you go, such as at C116A.
*The speaker field serves double duty as a filter choke, a common practice in old equipment.
Old 02-06-2012, 09:08 PM
vts1134's Avatar
Looking For Time
Check for ripple on the positive supply, first on the 'upstream' side of the spkr field* coming out of the rectifier (there'll be a large ripple here) and then on the 'downstream' side (top of C127A). Then at the top of C116B. The ripple should smooth out to just a volt or two and get progressively smoother the further downstream you go, such as at C116A.
Yep, this is exactly how the set is behaving. Progressively less AC as I move further downstream. By the time I get to C116A the ripple is less than a volt. A real for sure.
I thought outside the box today and considered that there was outside interference so I unplugged my LED work light transformer and every thing else on my bench to see if the problem was external to no avail.
Old 02-07-2012, 12:50 AM
miniman82's Avatar
First Light: 1952-2011
Have you considered an H-K short in the CRT?
Evolution...
Old 02-07-2012, 11:43 AM
By golly it looks like power supply ripple has been pretty decisively ruled out. I went back and reread the thread and looked more closely at the pics. Post#43 shows the raster as having nice straight sides (no hourglassing), indicating no appreciable ripple in the B+ feeding the H output stage (good). And post#58 shows the CRT displaying strong video which would rule out a heater-cathode short in the CRT (which would kill the video).
So.. it kinda looks like the hum is arising somewhere in the video chain 'upstream' of the CRT. And since the sync is affected too, the hum must be occuring upstream of the sync take off point. (Just guessing, but the sync may be picked off at the vid. output which was common practice in the old stuff.) It could possibly be nothing more than a H-K short in a tube. Sometimes tapping the tubes will show up an intermittent that won't show up on a tester.
If it ain't a tube, maybe you could post a pic showing the video amp and sync areas of the schematic.
Old 02-07-2012, 12:16 PM
miniman82's Avatar
Occam's Razor: you've been making cap upgrades which means you've been messing with the wiring, find the wiring fault and repair it.
Evolution...
Old 02-07-2012, 12:24 PM
Finding the wiring fault can be fun and challenging if you make it so. Also helps a Noob hone his skills. Sorta like in the old days an electronics instructor would deliberately introduce a fault into a piece of gear.
Old 02-07-2012, 04:37 PM
miniman82's Avatar
Tell me about it. When I went through AE 'A' school in Pensacola, I was forever finding faults with their trainers. Then again, they were as old as most of our sets...
Evolution...
Old 02-07-2012, 07:32 PM
vts1134's Avatar
Looking For Time
Check your work young student! Good advice for every restoration and I should have done it sooner. I traced every wire on every connection that I had my hands on and three hours later I'm vindicated but sad to report that I have not found a single wire/connection out of place.
I tried a few taps on each tube and no changes there. Maybe I can retest the tubes for HK shorts.
So.. it kinda looks like the hum is arising somewhere in the video chain 'upstream' of the CRT. And since the sync is affected too, the hum must be occuring upstream of the sync take off point. (Just guessing, but the sync may be picked off at the vid. output which was common practice in the old stuff.)...
It looks like the sync is taken off of the plate of the 2nd video amplifier. The video at this point carries the sync pulses with it to the sync amplifier which would magnify these signals. The sync separator would remove the sync pulses from the video (or does the term "separate" come from separating the horizontal pulses from the vertical?) and pass them on to the vertical and horizontal output sections. If this is correct and the problem is originating in the video section, is there a way to isolate every thing upstream from the 6SN7 sync amp/separator to quickly confirm this? Would removing the video amplifier tube achieve this?
I could be completely off base on my thoughts above but just trying to think it out as much as I can on my own so I can learn.
Old 02-07-2012, 07:50 PM
miniman82's Avatar
You can isolate everything from before the video amp by lifting the grid connection (V105 pin 1), then injecting composite video right into the video amp on pin 1. If the problem goes away, the issue is in the tuner/IF. If you remove the sync tube, the picture won't lock at all and I think it would be difficult to tell if there problem were still there or not.
Evolution...
Old 02-07-2012, 08:33 PM
vts1134's Avatar
Looking For Time
One last thought.
If the problem is coming from the video section would it still manifest itself with no video signal present?
