Old 02-12-2012, 05:19 PM
tubesrule's Avatar
tubesrule tubesrule is offline
I'm not sure why they show that. The voltage on the focus anode is going to vary between 1475V and 2250V based on the resistor values shown. The RCA spec sheet for the 7DP4 says it should average around 1800V for 7500V operation. Definitely need to use cation and a high voltage cap.
Darryl
Converters for obsolete standards:
www.tech-retro.com/aurora-design/legacy.html
Old 02-12-2012, 05:28 PM
Darryl
Good call. Maybe it's a misprint of 1495V.
Old 02-12-2012, 10:43 PM
earlyfilm's Avatar
Eternal Member
Re: +495 volts on focus anode on schematic
I'm not sure why they show that. The voltage on the focus anode is going to vary between 1475V and 2250V based on the resistor values shown. The RCA spec sheet for the 7DP4 says it should average around 1800V for 7500V operation. Definitely need to use caution and a high voltage cap.
Darryl
Darryl,
RCA specified that all voltage readings were to be read with a Voltohmyst. Those meters were very sensitive service meters for the era and only have a 11 meg ohm per volt circuit load on DC. The WWII era Voltohmyst was limited to 1,000 volts DC, without the high voltage attachment. (Confirmed by the manual for my RCA 195-A, although the meter scale goes higher. Duh ! )
Note the little asterisk beside the +495 volts on the schematic.
The asterisk means they specified that pin 6, the focus anode, was to be measured only with the brightness control turned fully counterclockwise. This would bias the Kinescope to cutoff.
I suspect cutoff would drop the focus voltage to within the range of the Voltohmyst. It also would increase the 2nd anode voltage to 7,500 volts, which most 1946 service shops could not measure.
This has nothing to do with curing the present vertical problem, but once the set is operational, it would be an interesting experiment to perform, since the focusing anode voltage dropping with beam cutoff, goes against conventional logic.
James.
Old 02-13-2012, 12:54 PM
tubesrule's Avatar
Darryl,
James.
James,
Something still doesn't add up. The focus voltage does not change much over the full operating range of the crt as the load is negligible. The RCA manual does indeed say that besides the Junior Voltohmyst you need the optional high voltage probe which allows measurements to 10KV. That must have been used only for the 7500V measurement as the Voltohmyst was capable of 1000V on it's own, so if the 495V is correct, the meter was used without the HV probe.
The loading of the meter is a fixed 11meg, not 11meg/volt, but even with this extra load, and with the focus control turned to the low side you still end up with 966V. With the control to the high side you get 1250V. I'm still guessing this was a misprint in the original RCA manual and just got duplicated in Riders and elsewhere.
I suppose one of us could go measure it on a working set. Since modern meters are 10M input impedance, any digital or VTVM should work.
Darryl
Old 02-13-2012, 01:22 PM
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
Well I did have some time today to apply the decals to the set. There were a few coats of lacquer applied to the set to smooth out the surface. There will be many more coats applied now to bury the decals into the finish. I was surprised to find out that the finisher never uses grain filler, instead he simply shoots lacquer and sands until he gets a glass smooth finish (if that is the goal). I'm very happy with the progress so far and can't wait until I see the finished product.
The sides of the set are a bit darker than the front and top. I would have been happier if they were the same color. The lighting accentuates this fact a bit more than what it looks like in person.
The decals are not 100% where they were before, but I think unless you had a picture next to it you'll never notice.
Now to get back to the chassis!
Old 02-13-2012, 05:13 PM
Glenz75's Avatar
Glenz75 Glenz75 is offline
NZ Vintage TV Collector
Wow! That cabinet work looks fantastic...She'll a nice set when its all back together :
Visit my Vintage TV & Radio Page - http://nzvintagetvradio.blogspot.com/
My YouTube Link - http://www.youtube.com/user/glenz1975?feature=mhsn
