Old 03-02-2012, 05:19 PM
tvcollector's Avatar
Zenith Roundie
I'm about to make a purchase of a Zenith Roundie and I'm trying to make sure the picture tube is still good.. He said he tested the tube and the filament lights up as it should, meaning it's hasn't gone to air.. He said he tested it in 35 degree weather and does get response on all 3 guns and got around .2 ma on each gun, cold, and said they should go up considerable if allowed to warm up.. I figured I would get some input..
Old 03-02-2012, 05:29 PM
just go git it! If it don't work you can bury it in the yard...
Old 03-02-2012, 05:37 PM
It's something far away that gonna cost a pretty penny for to have a moving company or something to ship..
Old 03-02-2012, 05:41 PM
tvdude1 tvdude1 is offline
Where do you live
Old 03-02-2012, 06:06 PM
I live in South Florida..
Old 03-02-2012, 07:47 PM
miniman82's Avatar
First Light: 1952-2011
Just because the filaments light up doesn't mean the CRT is still good... ask the many 21AXP22 dud owners. Good thing is it's a Zenith so it has a glass tube, making a leaker much less likely. Cold temps will make the guns read low, I think you'll be fine once it sees higher temps.
Evolution...
Old 03-03-2012, 03:07 AM
Ok, thanks for the input...
Old 03-03-2012, 07:30 AM
tvtimeisfun tvtimeisfun is offline
Hey hope you grab that roundie and wish you lots of luck great score...Timothy
Old 04-05-2012, 05:58 PM
I got the set and comes to find out the original Zenith 21FBP22 is pretty much dead, no emissions on all three guns, upped the filament voltage on the tester to 8 volts only to find out the emissions go up but down as the tube cools to 6.3 volt temp..
Old 04-05-2012, 06:20 PM
Did you let it cook for a while?
Old 04-05-2012, 06:46 PM
Yes, overnight, and it did not improve, not even by the least bit..
Old 04-05-2012, 06:53 PM
60s Throwback
What are your plans for the set now?
Old 04-05-2012, 06:58 PM
I'm trying to locate a 21FBP22, hopefully a Zenith, but if not, any make or model substitute will work as long as the tube has great emissions, no shorts, good tracking, and cut off..
Old 04-05-2012, 08:42 PM
rcaman's Avatar
rcaman rcaman is offline
i may be listing a couple on you know where excellent emmission rebuilds.
Old 04-05-2012, 09:01 PM
Excellent emission rebuild would be great, do you have one?
