Old 04-21-2012, 06:18 PM
Originally Posted by Pete Deksnis View Post
RCA F38310 38-in. 9X16 CRT 1999 set which, as I learned at a recent ETF Convention from a former member of the team who designed it, was not considered a true hi-def TV because it didn't qualify pixelwise
This really surprises me, Pete. I have seen those sets, and they always looked quite detailed. I would have guessed at least 1280x720 actual resolution (despite the chassis only sending a 1920x1080i signal to the CRT).
Old 04-21-2012, 09:39 PM
Pete Deksnis's Avatar
15GP22 demo @ ETF 2007
Perhaps running my f38310 with velocity modulation disabled accounts for lack of detail you mentioned. While I have no compunction against VCM, it seems, well, more civilized without it, although it does make the image crisper.
The story surrounding the 38-in. diagonal wide-screen RCA/Thomson-developed CRT has gotta be fascinating, but my knowledge is fragmented. I know there were at least three different versions: the RCA f38310, the Proscan P38000, and a German variant I once saw in a high-end video retailer, Harvey Electronics, in an Eatontown NJ store.
I had both an early production P38000 (made I suspect about or before August 2001) and a late production f38310 (June 2002) side-by-side in my living room for a week or so around September 2002. The P38000 outshone the f38310 by a shocking margin; my 'test' signals were simply ATSC transmissions available in the New York City area. WCBS-DT was particularly important as CBS was converting their programming to digital much ahead of the competition.
Anyway, the 'German' version and the early Proscan (I heard there was no difference between 'later' Proscan's and the f38310's) were the most impressive performers. The f38310 in my A-B viewing tests came in a noticeable second compared to the early P38000. That same f38310 is the one from which the screen shot in this thread came.
If memory serves, I understood it was these sets inability to display a million pixels that disqualified them as true hi-def ATSC sets. It would be interesting to learn more of the RCA/Thomson-era ATSC history.
Pete
Old 04-29-2012, 09:02 AM
RCAGuy's Avatar
RCAGuy RCAGuy is offline
RCAGuy
Pete
Thomson's RCA and PROSCAN widescreen sets were first introduced as NTSC models in 1993 with tubes from the company's picture tube plant in Italy, which also supplied other Thomson brands (such as the German TELEFUNKEN brand.) It would be the end of the decade (1999 or so) before the first widescreen HD picture tubes were available from Thomson's U.S. picture tube plant in Marion, IN. That's the tube used in the F38310, the affordable (at the time) 38-inch widescreen RCA set. Also far more popular at this time were "HD-ready" sets that had high-resolution picture tubes, but were 4:3 aspect ratio. This was before most programming was available in widescreen, so people were buying to see what was available on cable, broadcast, and satellite. These "HD-ready" sets were "almost" HD, given that they almost had 1M pixels when showing widescreen content and letterbox bars.
