Old 05-02-2012, 11:46 AM
NewVista's Avatar
NewVista NewVista is offline
Are these VTRs significant?
Picked up these -- seem to be 1960s monochrome - might record color ?
Old 05-02-2012, 01:23 PM
Heck yes! Check out the site Labguy's World it is one of the best sites regarding early VTRs.
And BTW "ah hate yew"!
Old 05-02-2012, 03:16 PM
Hey, Dammitt, that's MY line !! Work YOUR side of the Street ! (grin)
Old 05-02-2012, 06:04 PM
Dave A's Avatar
Dave A Dave A is offline
Those are Ampex Type A 1" helical scan decks. Probably B&W only. VP-xxxx = player. VRxxxx = recorder. It's a full Alpha wrap and the manual tape pull-in guides are prone to hitting the heads making a very distinct "ping" noise as the head flies across the room. Industrial and consumer grade. Not good enough for air. Probably blanking problems not up to FCC specs. And a stunning 300 lines of res. It was replaced by the invention of Type C which was in broadcast service for years.
I have one of the later ones in the attic. And until I get largish helpers, it is staying there. It has color capabilities if you add a color hetrodyne board. Not sure of my model number.
Then you have to find 1" video tape. They are a novelty only at this time. Not much value.
Check this Wikipedia for full model info on what you have and be sure to visit Lab Guy.
http://en.wikipedia.org/wiki/1_inch_type_A_videotape
Old 05-02-2012, 07:55 PM
NewVista's Avatar
Well, I see these ones are models 4900 & 5000 making them the first type A's (1965)
They have pretty blue PC boards and were surprisingly made in Chicago and not at Ampex's Silicon Valley Calif facility.
Old 05-03-2012, 02:46 PM
NJRoadfan NJRoadfan is offline
They are for folks who have tapes and need spares to keep working examples running. Here is a neat Type A tape restoration story: http://www.amiaconference.com/techre...rm_sargent.htm
Old 06-09-2012, 06:25 PM
4343's Avatar
4343 4343 is offline
Cool
I have one of the later ones in the attic. And until I get largish helpers, it is staying there. It has color capabilities if you add a color hetrodyne board. Not sure of my model number...
Unless you took the belts out before storing, expect to have a gummy mess inside when you do haul it down. The ones I had in the 80's had already done that, along with the Ampex consumer audio decks. (I'm hoping the modern belts in the audio deck don't go soft like the originals, cleaning the tar out is REALLY messy!)
Mike Scott in SJ, CA Drive 'em to the XMAX!
