Old 05-08-2012, 10:53 AM
Re-solder the vertical output IC. I've seen this problem on many brands of TV's. They are often not soldered very good to begin with and years of constant heating and cooling causes micro-cracks to develop in the solder; thus, causing an intermittent connection. It also wouldn't hurt to replace the electrolytic caps around the IC; but, I'm sure some fresh solder on the IC will fix the problem.
