Did I melt a resistor???
Working on my 1960 Magnavox set.
I finished installing the electrolytics, and had to wire in a resistor between two of them. When I heated the wires with the soldering iron, the resistor started bubbling a little on the outside. Did I do any damage to it internally? I was only at 15 watts. Thanks for any help! Magnavox300 |
I bet you're OK . Those carbon resistors are pretty tough. Just be careful with transistors, diodes/rectifiers when soldering.
Thanks Dave!!!!
Soldering
Sometimes a low wattage iron can take additional time to heat the joint and that lower heat coupled with the added time can cook parts. In such a case it is better to use a slightly hotter iron to get in and out quickly so the heat has less time to "travel". Just food for thought.
I can be a worry wart sometimes and test heated looking stuff or things that I may have damaged. Only takes two seconds to hookup an ohm meeter to a resistor and make sure....
How about an aligator clip on the lead to draw some of the heat?
Maybe there was some stuff on the outside of the resistor? Waxy buildup?
You would of melted the wires before that resistor. I agree with Einar, probably some kind of wax or something similar. I've seen stuff like that before. Not an issue.
"It's a mad mad mad mad world" !! http://www.youtube.com/user/mwstaton64?feature=mhee |
I have seen many 1 watt or larger carbon resistors in circuit and working fine with bubbling evidence which I would think is a normal part of their heat dissipation process. Some of what I have seen could have been in a circuit where a capacitor had at some point shorted or leaky and the problem was fixed before the resistors were damaged. I think they are pretty much OK up to the point of smoking out.
