Old 06-13-2012, 04:32 PM
Robb's Avatar
Robb Robb is offline
Question Which cable adapter/coupler/F barrel ?
Hello, I have an old vintage 1970's Zenith chromacolor TV, but the adapter broke off.
It was a female to female adapter, I think...
Which adapter would work on this ? (see pics)
Old 06-13-2012, 06:59 PM
Robb's Avatar
TV model is Zenith SG2570P
Old 06-13-2012, 08:13 PM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
It was a female F jack designed to be installed on the end of a cable, rather than being mounted in a panel. A direct replacement might be a bit tricky to find, but you could always install a standard male end on the cable, and add a F-F barrel connector to replace the original.
Old 06-13-2012, 08:16 PM
Robb's Avatar
Was it like this ?
Old 06-13-2012, 08:25 PM
Robb's Avatar
I also have the option of using one of these:
with this ?
Old 06-14-2012, 12:08 AM
The missing piece accomplished what you pictured in post #4, basically a crimp-on female "F" connector. If the first item in post #5 is a twist-on F plug, then yes, that with the double-female adapter in the second picture would do the job, as N2IXK said.
Old 06-14-2012, 10:16 AM
Robb's Avatar
Here is a pic of the cable I need if anyone has a spare !
(and a pic of the TV itself)
