This RCA Hi Lite difficult, didn't get it hot enough?
Was tapping in some wood shims and -Pop- safety glass cracked as there is no adhesion in cataract but strong adhesion in center. So be careful with shim pressure. Strangely though, PVA just peels off smooth CRT face once safety glass removed (Maybe vacuum really holding it on convex surface) The only upside for me is that I don't like the tint filter of (RCA) safety glass and will like to see picture/colorimetry thru modern clear soft safety plastic attach? |
Still have plenty , PM if you want sample
How warm and how long did you leave the tube in the sun?? Going to be in the 90's here today and I'm using the clothspin method. Thanks
Tom Smrz |
just tap them in until snug, then walk away for 30 min, check them and tap in until just snug. The idea is to apply a constant pressure, and let it slowly release, NOT to use them to force it off. If you look closely you will see what looks like finger shaped shadows begin to form, and extend from the edges toward the center, they will get fatter and begin to link up forming larger detached areas as the process continues. Also try to get the wedges placed so the pressure is at the inner part of the wedge not the outer edge of the lens, this will prevent excess pressure that will act like a lever to break the lens.
