Old 07-05-2012, 01:17 AM
toober toober is offline
Special DuMont 109 maybe available?
A friend has a line on a very nice looking DuMont 109 television in Boston, probably available for the taking.
But do not plug this into the wall - it is a weird DC variant. Apparently North Boston still had a bit of the old DC network in the 1950s, just as New York City still had DC in the 1990s. I have no idea how the power supply is different - probably a vibrator.
Anyway, if there is any interest, I can bother my friend a bit more.
Will
Old 07-05-2012, 07:21 AM
Steve McVoy's Avatar
I can't imagine a vibrator being hefty enough to provide the power needed for a 40s TV set, but I can't figure out another way they would do it. Please get more information.
Old 07-05-2012, 07:24 AM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
Dynamotor maybe? Would be really annoying to listen to it whine while trying to watch TV, though...
Old 07-05-2012, 10:44 AM
Zenith26kc20's Avatar
Zenith26kc20 Zenith26kc20 is online now
a supply like a sweep circuit to make B+ would be possible but the current would take quite a output tube to work. Possibly a push pull type supply with some HOT's would work and keep you warm in the winter!
Old 07-05-2012, 11:57 AM
I have a couple Raytheon sets that were also designed for AC/DC.
The rectifier assembly plugs into an Octal socket on the chassis and can be replaced by whatever it is that makes it work on DC, but these are also series strung with no transformer.
I can't imagine a DuMont without that massive Sola Transformer on the chassis?
Old 07-05-2012, 12:07 PM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
I'd like to see a picture or two, my 109 sits awaiting a 19AP4 rebuild or the 21" rectangular conversion I saw on eBay once...
Old 07-05-2012, 12:31 PM
Eric, are you sure these sets were designed for DC? I can't imagine how they would work, since the B+ would only be 120v.
Old 07-05-2012, 12:38 PM
Steve, yes.
Take a look at Sams 75-1 http://www.earlytelevision.org/image...43-Sams-75.pdf
It has the option for DC power with a "Polarizing Relay" (vibrator?) the diagram is on page two.
You're right about the B+ I don't see anything higher than 127 volts listed in the voltage chart.
It has no Flyback using an RF type supply so maybe that's why. I'm guessing they managed to duck most or all of RCA's Patents with that chassis!
Old 07-05-2012, 12:53 PM
Amazing. Yes, it is a vibrator. Must be a hefty one to power that set - 1.7 amps at 117 vac.
Old 07-05-2012, 02:03 PM
hi_volt's Avatar
hi_volt hi_volt is offline
Vintage TV and Radio Nut
Sounds fascinating from a technical standpoint. Hope someone gets it and shares photos.
Old 07-05-2012, 02:19 PM
I hope we see a schematic also! That Raytheon is TWISTED! Three 50B5 audio outputs in parallel! And yes, a vibrator! Can you imagine having to replace the vibrator! The customer would be boiling oil to throw!
Old 07-05-2012, 02:48 PM
David Roper's Avatar
console lover
Correction: the 50B5s are horizontal outputs in parallel. It hardly gets more twisted than that.
tvontheporch.com
Old 07-05-2012, 04:25 PM
Tom Albrecht's Avatar
I recall marveling at the oddity of the Raytheon design when I scanned that SAMs and submitted to ETF. Three 50B5s in parallel for the hz output, and a 35Z5 for damper!
Looking carefully at the circuit, I believe the "polarizing relay" is NOT a vibrator, but merely a relay which makes the set work regardless of which way you plug it into a DC outlet. Probably a relay with a permanent magnet that is sensitive to polarity of current in its solenoid.
Note how the voltage from the output of the polarizing relay bypasses the filter, which would not be done if it were a vibrator. Also note (as mentioned above) that the are no DC voltages over 120 VDC in the voltage chart (except where boosted by the hz output).
Old 07-05-2012, 05:25 PM
Tom, thanks for setting the record straight. Amazing that they could make a set with maximum B+ of 120. I guess there was a market for DC sets, since there were still pockets of DC power in the US in the late 40s.
Old 07-05-2012, 08:02 PM
Doing that would avoid the voltage drop you get with tube rectifiers, and hopefully gives enough protection to the electroytic caps against reverse polarity. If the relay is normally open with no power applied, then maybe only when it sees power it makes the correct connections without the caps ever seeing reverse polarity. Like a cross wired DPDT switch with center off.
