Old 07-13-2012, 11:41 AM
63 silvertone roundie
hey all, this set developed rgb retrace lines from top to bottom they are faint but i can see them which were never there. crt bias counter clockwise and the rgb drives are low. any quick fix that anyone may have an idea befor i go full blast into this set to look?
Old 07-13-2012, 12:22 PM
ctc17 ctc17 is offline
The color is working right otherwise? Do they go away if you turn the color all the way down?
Old 07-13-2012, 12:41 PM
color down they are still there, otherwise its working great.
Old 07-13-2012, 01:14 PM
marty59's Avatar
marty59 marty59 is offline
Are they only visible in "low light" or "high light" areas of the video? Or all the time?
Old 07-13-2012, 02:33 PM
high lights in the video it can be seen.
Old 07-13-2012, 03:24 PM
Most TV sets use a pulse from the vertical output to drive a grid in the CRT to make the CRT cut off. If the set sends the video to the cathode, as most do. Bad capacitor?
Are you trying to watch a DVD or tape with Macrovision pulses in the vertical interval. These come and go every minute or so.
Old 07-13-2012, 03:25 PM
Have you checked the video output tube for shorts? It's probably a 12BY7 if it's an 11 or 12 clone. When mine developed a short the exact symptom you described showed up.
Old 07-13-2012, 03:51 PM
no dvds just tv. a cap, in the vert board?
Old 07-13-2012, 04:43 PM
red green and blue bars running up and down?
That is one I have never seen. Almost sounds like some low level ripple getting into the chroma board. Maybe a heater to cathode leak in one of the 6GU7s or other tubes in that area? Weak filter? Video tube with some weird condition like mentioned.
I would start pulling the tubes behind the 6GU7s out one at a time with the color off and see if it you can get it to go away.
Old 07-13-2012, 04:51 PM
the 3 color lines are left to right but each section of bars start on top and kind of fade toward the bottom.
Old 07-13-2012, 05:46 PM
mstaton's Avatar
mstaton mstaton is offline
"Book em Dano!"
Can you post a picture? It would be most helpful.
Old 07-13-2012, 05:55 PM
probably not be able to see them as they are very light.
Old 07-14-2012, 04:10 PM
marty59's Avatar
I'd also look at voltages around the video output as well as making sure the service/normal switch is good and follow out to the drives and do some resistance checks/troubleshooting in that area. Do brightness and contrast work normal and is there any effect on your symptom?
