Westinghouse LCD TV's are plagued with power supply problems and main board problems. More than likely it had a Wii Accident that is all too common. Along with Polaroid(more like hemorrhoid) and a few others are the bottom of the barrel for flat screen TV's. Best to leave it in the garbage where it belongs.
"It's a mad mad mad mad world" !! http://www.youtube.com/user/mwstaton64?feature=mhee |
You mentioned a "Wii accident" that can ruin these TVs. What harm can a Wii video game console do to the set? Do the consoles run the panel at such high brightness (much higher than normal video drive levels) that the entire video chain eventually burns out, or the panel itself is damaged or destroyed by image burn-in? I realize image burn-in is not as common with LCD televisions as it is with plasma flat screens, but I do believe it is possible to burn a stationary image permanently onto an LCD screen if it is bright enough and it remains motionless on the screen long enough, not unlike screen burns on old CRT TVs.
http://en.wikipedia.org/wiki/Tsinghua_Tongfang_Company Tsinghua TongFang Company currently rates 23rd most-reliable video electronic manufacturer in the world. http://www.avsforum.com/t/1403415/wh...#post_21914558 |
That was probably two years ago and the TV is still running. It's used in a local thrift store. As such, quality is likely all over the map. Quote:
